10-17-2014 11:47 AM - edited 03-19-2019 08:44 AM
Hi all,
Anyone know if there is a way to force all voice mail subscribers to change their PIN at the Next Sign-in ? I am running Unity Connection 8.0.2
Also, is there a way to run report on password changes in Unity Connection ?
Thanks in advance !!
Danny
10-17-2014 02:33 PM
You will have to run a BAT job to set the user to change PIN at next sign-in.
You can generate and view reports in Cisco Unity Connection Serviceability.
Log in to Community
