Unity Connection Integration
paulblakie
Level 4
Level 4
Since the PIMG is EOL, I have a Unity Connection integration question.
Is it possible to integrate Unity Connection via SIP to a Nortel CS1000 such that calls to and from voicemail will be delivered and MWI will light on the Nortel phones?
I have checked the interoperabiltiy portal, and there is no Unity Connection information.
5 Replies 5
cbarlow
Hi Paul,
Only the Mitel and Rolm PIMG units are EOS/EOL:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps6509/end_of_life_notice_c51-727387.html
The Analog and Digital PIMG units are still available.
Unity Connection does not support a direct SIP integration to the Nortel CS1000.  Unity Connection would require CUCM-SME in between the Nortel CS1000 and Unity Connection.  Note that with CUCM-SME 8.5 and later, there is now the ability to create SIP normalization scripts to take care of the voicemail integration issues documented here:
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns832/822195_2.pdf
-Chris
Hello, would this be the only possible solution today?
I am looking for different options to integrate CUC with a Avaya CS1000.
You should be able to setup a SIP trunk between the CS1000 and CUCM. After that, you can make the RONA for the phones on Avaya/Nortel forward to a CTI Route Point in CUCM that send the call to CUC. This is how I have done most of my legacy integrations that are SIP capable, rather than trying to point directly to CUC or using a PIMG.
https://www.cisco.com/c/dam/en/us/solutions/collateral/enterprise/interoperability-portal/avaya-app-note-external.pdf
Mike,
      Do you happen to have a copy of this or a newer version? It is no longer a valid link.
Another option is to integrate it with a QSIG PRI. I have done this with an MGCP gateway running QSIG registered to CUCM and the PRI side connected to a CS1000. I don't know if it is possible to do it without CUCM. I suppose it might be possible to have a SIP integration between Unity and CME, and you could have the appropriate dial peers in CME to point the DN's down the QSIG PRI to the CS1000.
