VG310 mgcp fax t38 inhibit after reboot
thomas.lutz
i've updated a VG310 from 15.6.3M6 to 15.9.3M9.
Since then after every reboot "mgcp fax t38 inhibit" shows up in running-config. I don't want that config parameter.
After a "no mgcp fax t38 inhibit" and save to startup-config it's gone but after the next reboot it's there again.
A reset of the VG310 from CUCM doesn't trigger this.
Any ideas?
Does the command reappear after you remove it if you do a "no mgcp", wait for teardown to complete, and then "mgcp"? If so then the config is being pushed from CUCM. You need to change options there so it is not pushed to the gateway.
