Unity Connection license file 7.0 for CNX 2.1
End user has unity connection 2.1 and is about to add more more ports. I notice that the license file in for CNX ver 7.0 not 2.1
Would it be any problem if I try to load the new license file?
regards
Rob Huffman
Hi Filiberto,
I can't see it causing any issues, it will likely just be rejected if not
valid. If it were me I would just contact;
licensing@cisco.com
let them know this problem, include the license file and ask them to
re-issue the file for CUC 2.1 instead of 7.x. You will want to give them the
PAK# as well
Cheers!
Rob
Rob Huffman
Hi Filiberto,
licensing@cisco.com
PAK# as well
Cheers!
Rob
Hi Rob,
Thanks a lot for your recommendation and time.
I will follow it.
regards
p.s. 5+ for you
