Unity Connection: Multi language Greetings, Limit to user language
etamminga
We have an Unity Connection installation with multiple languages installed.
Now when the user records greetings via the Phone Interface the interface presents a list of languages to record in. We'd like to limit the user to only record in his/her language and not in any other language. Can this be configured?
Currently we see that users record greetings in the wrong language resulting in wrong prompts being played when callers are forwarded to voicemail.
Erik
JAMES THOMAS
Where you ever able to solve this?
Ratheesh Kumar
Hi there
If you installed multiple locales then each user record greeting in different language and the language greeting will be played on based on "inherit language" feature. By dialing from phone it use the default routing rule, and you can create custom rules.
Multi-Language Call Routing Unity Connection
https://www.uccollabing.com/busy-unavailable-greeting-dial-by-name/
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
