ā03-24-2017 11:50 AM - edited ā03-19-2019 12:15 PM
I just setup a new cuc system and imported users via ldap with extension numbers in range +1654XXXXXXX. My pilot number is 16542351234
A user can push the message button and access their mailbox after signing in. However when i call any user with cfwd no answer or busy to voice mail set, i hear the " Hello Cisco unity connection messaging system" message. I look at the port monitor in RTMT and called number is my CUC pilot 16542351234, and not the extension i called. This happens for both internal extension dialing and calling a user from PSTN. What am i missing?
Nki
Solved! Go to Solution.
ā03-25-2017 09:01 AM
The called number will always be the pilot. A forwarded call will show the voicemail user in the first redirecting party field.
What's the mask on the voicemail profile?
Is outbound Diversion header enabled on the SIP trunk to CUC?
ā03-28-2017 04:52 PM
I enabled outbound Diversion header on the SIP trunk to CUC and started working. Thanks
