Unity connection pilot not work after publisher down
samhopealpha
Level 2
Level 2
Dear everybody,
I have a problem on unity connection.
Here is the environment
- CUCM 8.6 publisher
- CUCM 8.6 subscriber (primary TFTP)
- CUC 8.6 (Telephony integration > port groups > edit > server > IPv4 is pointing to publisher)
everything works fine when all servers are UP
However, if I unplug the cable for the publisher,
- all IP Phones work fine
- MWI on/off still working after dial the MWI on/off number on IP phone
- BUT if I dial the voicemail pilot number or press the message button on IP Phone, there is no response on the phone and disconnect itself finally.
Anybody knows what is the problem? and what should I need to do to ensure the CUC available even the publisher connectivity is lost?
Thanks in advance
Sam
Rob Huffman
Hi Sam,
Can you check these settings in CUC for the "Secondary" CUCM server config;
Step 32 On the Edit Servers page, do the following substeps if the Cisco Unified CM cluster has secondary servers. Otherwise, skip to Step 33.
a. Under Cisco Unified Communications Manager Servers, click Add.
b. Enter the following settings for the secondary Cisco Unified CM server and click Save.
Table 6-16     Settings for the Cisco Unified Communications Manager Servers
Field
Setting
Order
Enter the order of priority for the Cisco Unified CM server. The   lowest  number is the primary Cisco Unified CM server, the higher   numbers are  the secondary servers.
IP Address or Host Name
Enter the IP address (or host name) of the secondary Cisco Unified CM server.
Port
Enter the TCP port of the Cisco Unified CM server that you are    integrating with Cisco Unity Connection. We recommend that you use the    default setting.
TLS Port
Enter the TLS port of the Cisco Unified CM server that you are    integrating with Cisco Unity Connection. We recommend that you use the    default setting.
Server Type
Click Cisco Unified Communications Manager.
http://www1.cisco.com/en/US/docs/voice_ip_comm/connection/7x/integration/cucm_sccp/guide/cucintcucmskinny050.html
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
Rob Huffman
Hi Sam,
Field
Setting
Order
Port
TLS Port
Server Type
Cheers!
Rob
