Unity Connection PIMG MWI
Tommer Catlin
If I have only 2 ports with the PIMG, and CUC fails to send the MWI because the port is busy, will it attempt to light the light again or make a second call?
Ginger Dillon
Hi -
On the Port Group Basics, message waiting indicators, for the PIMG, do you see this as an option?  I don't have a PIMG integration to check currently.
Ginger
Retries After Successful Attempt
Enter the number of times an MWI request is retried after success is reported so that MWI success is assured.
Default setting: 0 retries.
Here is the guide I was referencing - http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/gui_reference/guide/7xcucgrg120.html
