unity connection publisher and subscriber cant see each other???
baselzind
Level 6
Level 6
today i logged into unity connection "publisher" version 10.5 to find a warning message " Communication is not functioning correctly between the servers in the Cisco Unity Connection cluster" then i went into the subscriber unity connection to find these two messages " Communication is not functioning correctly between the servers in the Cisco Unity Connection cluster" and  "The Cisco Unity Connection cluster subscriber server has changed to Primary Status (failover has occurred)" , the strange thing is that i can ping both unity connection servers from each other yet they cant see each other? what can i do?
9 Replies 9
Manish Gogna
You can try the suggestions in the following post
https://supportforums.cisco.com/discussion/12234121/cucc-subscriber-server-has-changed-primary-status-failover-has-occurred
Manish
that guy issue is different because his two unity servers can see each other while mine cant , when i go into cluster management the "make primary" is greyed out
In that case run the  "utils cuc cluster overwritedb" command on the Subscriber server . This copies database from the Publisher server to the Subscriber server and establishes replication.
Manish
but can i copy the data base if they cant see each other shown in the screenshot?
I had this exact scenario in a Rls 15.0 Pub/Sub cluster. Pings to and from each server showed connectivity was good, rebooting each server did not clear the issue. I ran the "utils cuc cluster overwritedb" command on subscriber and issue was resolved once replication was completed and Sub rebooted. Thanks for the help.
Did you try restarting the CUC cluster, if not then try that first as a starting point and take from there then.
Deepak
how do i restart the cuc cluster? by restarting both servers individually?
Yes that is correct, first restart the publisher using the command utils system restart Once that comes up, then restart the subscriber using the same command.
Deepak
NasrinYunus
hi, i also facing same issue. Did your problem resolve. if resolve what step you do.
