Unity Connection Single Inbox with Office 365
gmartindell
I've seen a couple of posts around the same issue, but none I've seen that have provided a solution that have worked for me.   When configuring unified messaging with Office 365, can anyone tell me what I need to put in the "Active Directory DNS Domain Name" and "Active Directory Site Name" fields when configuring a unified messaging services account in Unity Connection 10.5?
I would assume in the "Active Directory DNS Domain Name" should be "company.com" but am not sure what to use for the site name?
Thanks in advance,
Glenn
Chris Deren
You put what MSFT gave you which I believe is always ending with ".onmicrosoft.com" for example companyX.onmicrosoft.com
Thanks for the reply Chris.  I've tried that with no luck.   When I click the test button in CUC, I get "Failed to locate a Domain Controller via DNS"   Is there anything special I need to put in DNS for this?
Glenn
Did you ever figure this out?  We're stuck on this right now with Unity 11.5.
Try blanking out the Proxy address.  Someone documented an example and blanking it out for me fixed the issue.  Remember - test at the User level after clearing the proxy too (some posts have noted testing at the Unified Service level can be sporatic).
