Unity Connection SMTP Notification Changes - Need Help
balukr
Level 2
Level 2
We upgraded our Unity Connection from 2.X to 8.6.2 recently and we saw change in Email/SMTP notification, in CNXN 2.X when a user recieves Email Notification it used to list/send all "Unread" messages, for example if I have 2 unread messages already and if I get a new VM on my mailbox when I receive notification email I use to get information for all three "Unread" messages now I get only one for each VM and that is it.  Is this changed in  Unity Connection 7.x or 8.x or am I missing anything on the settings? Thanks for your help in advance.
5 Replies 5
Ron, Thanks for your response. Users get email notification without any issues but they use to get information about all the unread messages every time when they receive a new voicemail but now they receive info only about the new VM not other unread messages. I don't see we are missing any settings on this page unless you point me out. Thanks for your help .
Rob Huffman
Hi bala,
Do you have "All Messages" set?
Step 10   In the Notify Me Of section, select the types of event that will cause Connection to send a notification to this device:
Option Description
All Messages
Connection sends a notification to this device when any new message is received, including dispatch and other voice messages, and fax messages.
All Voice Messages
Connection sends a notification to this device when any new voice message is received (including dispatch messages).
Dispatch Messages
Connection sends a notification to this device when any new voice message is received that is marked as a dispatch message.
Fax Messages
Connection sends a notification to this device when any new fax message is received.
Calendar Appointments
Connection sends a notification to this device for an upcoming Outlook appointment.
Calendar Meetings
Connection sends a notification to this device for an upcoming Cisco Unified MeetingPlace or Cisco Unified MeetingPlace Express meeting.
Cheers!
Rob
balukr
Level 2
Level 2
Rob, I thought this setting is notify all messages like email , fax, vm, etc. let me check and get back to you.
Rob, Just an update that "All Messages" made no difference it is still sending individual message notification and not all Unread messages.
