Unity Connection Subscriber 14.0 SU2 Installation Fails
aniket0422
Hi There,
Facing issue with Unity Connection 14.0 SU2 Subscriber Installation. Installation keeps on failing with below error message.
1. NTP is synchronized with stratum 1 on Unity Publisher. Its IOS based NTP.
2. Unity Publisher is up and running fine
3. Tried without DNS entries and with DNS entries.
4. Tried changing security password on Unity Pub.
A couple of questions: Are you installing directly or through PCD? Are the Pub and Sub co-located or across the WAN? If across a WAN, are all of the appropriate ports open? For your DNS records, are both the forward and reverse records in place for both the pub and the sub?
Have you clicked "Continue" and gathered the dump file? If not, can you do that and post it here?
Maren
