Unity connection voice mail box routing.
rferullo
I am looking for a possible solution.
I have a call forward all on boss phone to assitants phone...on ring no answer on assistants phone, I want it to roll to the assistants voice-mail box instead of the default behavior of landing on the bosses voicemail box.
Is this possible?
(Unity Connection 8.6.2)
Robert
bmcghee
Mr. Ferullo!
How have you been man? Hope things are good. Did you try setting the assistants cfna to *xxxx (where xxxx is the assistants extension) ? That might work :). Tell everyone over there i said Hi....
Hi Bobby.
I want the assistance phone to have the option to be able to answer phone and only roll to her VM if she doesn't answer.
Thanks!
Oh ya so like this:
This should forward any calls not answered to the assistants vmbox as long as there's the forward to VM profile with the *XXXX pattern.  There's other ways to do it but this would probably be the least intrusive for other calls being forwarded to unity from that DN...
Dennis Mink
In the message settings of the boss in CUC go to EDIT>Greetings
select "standard"  and choose "after greeting" to go to the assistant's mailbox (user with Mailbox)
Please remember to rate useful posts, by clicking on the stars below.
