Unity connection voicemail deletion 6.1.1.2000-3
nuinoahmed
We faced a problem with HD usage on cisco unity.  When I check the diskusage see:
admin:show status
Host Name    : Unity
Date         : Fri Dec 2, 2011 00:34:15
Time Zone    : Europe/Paris
Locale       : en_US.UTF-8
Product Ver  : 6.1.1.2000-3
Platform Ver : 2.0.0.1-1
admin:show diskusage common sort
his command can take significantly long time,
and can also effect the system wide IOWAIT on your system.
Continue (y/n)?y
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/cciss/c0d0p6     43340336  36506360   4632412  89% /common
<removed>
18886560        /common/var-connection/mail
18886556        /common/var-connection/mail/unitymbxdb1
708976  /common/var-connection/mail/unitymbxdb1/2011.06.24-21.51.12.583
708084  /common/var-connection/mail/unitymbxdb1/2011.05.27-09.23.48.337
700616  /common/var-connection/mail/unitymbxdb1/2011.06.26-11.39.46.694
669464  /common/var-connection/mail/unitymbxdb1/2011.05.24-15.51.41.621
646180  /common/var-connection/mail/unitymbxdb1/2011.06.09-10.58.15.598
645844  /common/var-connection/mail/unitymbxdb1/2011.04.14-08.47.09.500
634640  /common/var-connection/mail/unitymbxdb1/2011.06.26-19.30.11.657
617064  /common/var-connection/mail/unitymbxdb1/2011.06.18-01.12.27.068
Anyone knows if it is possible to remove the .wav files under the above directories?  Or can we delete the directories under "
/common/var-connection/mail/unitymbxdb1"
Jonathan Schulenberg
These WAV files are your voicemails! You can force them to be cleaned up by modifying the message aging policy. Also be aware that each message store (i.e. unitymbxdb1) has size limitations of it's own. If adjusting the message aging policy does not get you sufficient space you may need to move to larger hard disks in the server. This would require a backup/install/restore sequence.
Please rate helpful replies.
Thanks Jonathan for your reply.
When I look to unitymbxdb1 with the browser I  see it at about 1G size.(End users clean up was requested/in progress).
Its size with ssh connection is 18G!
With Unity version  2.1, aging policy seems to be for only read/saved voice mails.  So if  voice mails are unread then the aging policy is not applied to them (As  per cisco TAC engineer as this unity version 2.1 not 8.x)
But I am still wondering why we can not delete files/directories under "/common/var-connection/mail/unitymbxdb1"?
