Unity connection voicemail deletion
nuinoahmed
Good morning,
I am working on an issue were the cisco voice mail unity HD is at about 95%.   After troubleshooting I found that voicemail are never deleted (50% of he HD)
I would like to delete few directories under /common/var-connection/mail/unitymbxdb1/
admin:show diskusage common directory
This command can take significantly long time,
and can also effect the system wide IOWAIT on your system.
Continue (y/n)?y
Filesystem            Size  Used Avail Use% Mounted on
/dev/cciss/c0d0p6      42G   37G  2.9G  93% /common
16K     /common/lost+found
50M /common/var-connection/mail/unitymbxdb1/2009.09.05-13.29.16.875
107M/common/var-connection/mail/unitymbxdb1/2009.09.12-10.30.16.156
121M/common/var-connection/mail/unitymbxdb1/2009.09.23-17.15.48.205
118M/common/var-connection/mail/unitymbxdb1/2009.10.07-10.33.35.368
168M/common/var-connection/mail/unitymbxdb1/2009.10.20-10.04.29.256
251M/common/var-connection/mail/unitymbxdb1/2009.11.02-10.38.21.005
23M /common/var-connection/mail/unitymbxdb1/2009.11.13-12.10.26.241
260M/common/var-connection/mail/unitymbxdb1/2009.11.15-18.31.22.608
273M/common/var-connection/mail/unitymbxdb1/2009.11.25-18.42.32.836
261M/common/var-connection/mail/unitymbxdb1/2009.12.08-10.27.34.058
315M/common/var-connection/mail/unitymbxdb1/2009.12.18-11.11.58.090
210M/common/var-connection/mail/unitymbxdb1/2010.01.12-10.41.40.913
222M/common/var-connection/mail/unitymbxdb1/2010.01.25-10.59.59.435
Please let me know if you need further info.
Thanks.
keglass
Level 7
Level 7
Ahmed,
This community does not provide technical support and is not staffed with technical support experts.  I recommend you post this and future technical support questions to the Cisco Support Community (https://supportforums.cisco.com/index.jspa. Another option is to open a ticket with the Cisco Technical Assistance Center (www.cisco.com/go/support) to get expert debugging assistance.
We hope to hear from you again.
Kelli Glass
Moderator for the Collaboration Community
