Unity - Name in body of html notification
Y C
I was wondering if it's possible to have a first / last name shown in an html notification when a voicemail comes in. There's the %SENDER_ALIAS% variable but that just displays the account's user ID. There's %CALLER_ID% but that displays the digits. The full name comes in on the subject but I couldn't find the variable that's tied to.
I looked at custom variables but I'm not sure how to tie one to an AD field.
Y C
Any thoughts on this?
victor.ortizDD
Hello, I have the same limitation  but I cannot find any other variable to use or did you find something ?
in last 3 month, i has this issue on 2 projects of mine, and what i realized is this >>
"Custom Variable" is only an static parameter which you defined it's value & exactly use that value on your HTML body.. and it's not possible to refer & tied it to an external value, e.g. AD vale..
also about name, try this >> %NAME%
and see it what's happens..
(Rate by "Helpful" or "Accept") (محمدرضا هادی_ایران) (Email: morez.hadi@gmail.com)
