Unity not answering
slc2
UM 4.04sr1, w2k, Exchange 2003.
This morning found Unity not answering calls. The only error I found is:
Event Type: Error
Event Source: CiscoUnity_ConvAddrSearch
Event Category: Error
Event ID: 109
Date: 8/31/2006
Time: 7:21:08 AM
Description:
Unexpected entry into a subroutine of the subscriber search conversation. Address Searcher Evaluate Input State should not be called without digits. Possible causes could be memory corruption of a switch integration issue. 205
Several ports showed busy for 23+ hours. I also observed status monitor showing calls coming in but, while listening it was not answering. After rebooting, everything worked fine. Any ideas?
Hin Lee
change HKLM\Software\Active Voice\MIU\1.0\Initialization\MutexSleepTimeMS to 500ms or 1000 (for a full second)
this might be related to CSCef80398 MIU - Exceptions after Unity srvr reboot causes calls no ans.
Hin Lee
posted es35 for you.
Thanks for your response. I already have ES35 installed and the registry changed to 700ms.
