Unity VMO PIMG w/Nortel and Digital Networking to another Unity VM Only
aramos17428
Hi everyone,
Will Unity digital networking work in the below scenario?
CallManager version 5.X with
Unity VM Only version 5.X with local exchange 2003 digital networked to another Unity version 5.X connected to a Nortel via PIMG?
The requirement here is to be able to forward messages bewteen Unitys.
The doc points that I need both Unitys to be part of the same root domain, so if my Domain is "Voice" when I'm building the 2nd Unity I will need to join the "Voice" domain and be able to see subscribers from both Unitys is this correct?
Armando
ranpierce
Level 6
Level 6
No not correct, you will never see all the subscribers from both Unity server at one time the way Unity is at this time.
You have to configure Digital Networking also. (Primary location and dialing domains)
Both Unity servers also have to be in the same dialing domain.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/networking/guide/ex/5xcunet020e.html
Hope this helps
rlp
Thanks RanPierce for your time and response
I will try it and provide an update.
Armando
