Usermigration between Clusters?
ausarkan
Challenge:
We would like to migrate users from existing clusters (CUCM rel. 4.x /5.x/6.x) to a another cluster to consilidate all user.
How can we achieve this regarding licenses files?
Many thanks
August
skilambi
August
Yes you can consolidate clusters into 1. See here, you have to work carefully with licensing to merge all the files to the new server
https://communities.cisco.com/message/59767#59767
Srini
Thanks for your quick response.
Is this also possible if the users will not move with via big bang from the old to the new cluster, when there is a migration scenario with severall branches.
So we have to reallocate branches over a longer time frame to the new cluster?
Do I have also to do the DMA process in this case?
August
I haven't personally dealt with the scenario however you can also work with licensing and manually fill the licensing sheet to let them know what the other clusters are licensed for while you do the phased migration
Srini
