02-15-2009 08:53 PM - edited 03-18-2019 10:30 PM
We will be integrating our UCM 6.1.2 with CUPS 6.x with MOC as the client. On the DN page of the UCM right at the bottom is a button titled 'Associate End Users'. As per the documentation this is required but I still am wondering if this association is really necessary as I will need to update all of our users via BAT csv which will be a lot work provided it can be done via BAT? The users page has an entry under device associations and the primary extension under directory number association has an entry as well so hopefully this will suffice.
03-10-2023 05:26 AM
txt file, but it should not matter, both should work.
03-10-2023 06:00 AM
03-10-2023 06:02 AM
user id Error Code Error Description
Bat file format: missing header
03-10-2023 06:34 AM - edited 03-10-2023 08:22 AM
You still have the wrong information in the header and the format of the file is also wrong.
03-10-2023
07:26 AM
- last edited on
03-15-2023
10:56 AM
by
shazubai
Please tell me what is wrong in the format, I performed a search on CM to output the data with those headers. So Im a bit confused whats is incorrect now.
03-10-2023 08:21 AM - edited 03-10-2023 08:38 AM
There where two errors in your files.
Try with these files that I modified based on your last shared files.
03-10-2023 11:52 AM
Well that worked so well
I have learned much from you Roger, Question did you just reopened in Excel and changed the format to comma separated ?
Awesome
03-10-2023 12:51 PM
No I opened your files in Notepad++ and copied my header line and then used search and replace. Excel would absolutely work if you save it as a CSV file, just make sure that the delimiter is a comma, which it is not in Sweden where I live. So I would anyway need to edit the file in a text editor, like N++, to replace ; with ,.
05-05-2011 08:41 AM
Hi all, new poster here. I'm attaching a CSV that I used once before that populated the
fields properly. Lots of times when I'm trying to figure something out about BAT (when
Cisco documentation is lacking), I'll do a full export and test with different fields until I
find the right one to populate. The User ID 1 field is what populates this if I'm not mistaken,
and the name in the field has to match exactly with the username in AD, case sensitive.
If the case is off then it won't work. I hope this is helpful as I spent several hours trying
different ways to make this happen. We are on CUCM 6.1.4. Kudos, JL
03-10-2023 06:56 AM
System version: 11.5.1.21900-40, This is the version I am on.
I tried to use the BAT.xml file but there was no option for selecting Partition only E164
So I will not change the txt file I have to .csv just by changing the name and see if it will take it
03-10-2023 07:19 AM
