users getting a "Invalid entry" issue when logging into their voicemail with their IP Phone
Natalie Ramirez
users getting a "Invalid entry" error issue when logging into their voicemail with their IP Phone for the first time. Cucm 9.1.2.12900-11 unity connection 9.1.2Es2.11002-2 please help
Rob Huffman
Hi Beau,
Is this when users are trying to go through the "first time enrollment" and entering the PIN?
Cheers!
Rob
Hi Rob ,
We are also facing this issue "invalid entry " and yes these are the IP Phones trying to access the voicemail for the first time.
Looking for you response.
RB
Has anyone had a resolution this issue? As I am experiencing the same
Kind Regards
Amre
Can you try resetting the user pin by doing below for the problematic user and see if that helps:
Go to Unity Connection >> Users >> Find the user >> Edit >> Change Password
Deepak
