voice gateway
shaikh ibrahim
                       what are configuration required to make cisco voice gateway to work mgcp and H.323 same time.
Shib
Chris Deren
you do not require anything different from normal config to run both protocols as long as you do not attempt to control the same voice port. Is there a reason you need both?
Chris
Actually . i am using mgcp protocol b/w VG nad PABX through E1.. i would like to use FXO port for right fax through H.323
protocol...
shib
sure, just configure one of your interfaces for h323 and add dial peers.
