VWIC-2MFT-G703
Sharleen Suarez
I would like to inquire if the module VWIC-2MFT-G703 or VWIC-1MFT-G703 still needs DSP resources (PVDM) if it will be used for unstructured E1 (using 120 ohms RJ-48).
Sharleen
nalbert
Level 4
Level 4
Sharleen,
DSPs are needed if you are doing VOIP on the unstructured E1. It you are doing data then it is not needed.
Navin Albert
