04-21-2015 01:37 PM - edited 03-19-2019 09:30 AM
So here is the current environment:
CUCM Version 7.5 on MCS hardware, one PUB and 2 SUBS.
Unity Version 5 on MCS hardware! Windows based!
UCCX Version 8.0 with two servers.
2 MGCP PRI Gateways about 100 users
Goal - Move to UC hardware, VMware and Version 10.5 across cluster. All input is welcome! Trying to resolve the inter-dependencies as to which intermediate moves to make. Get the entire cluster on a common version like maybe 8.0 or 8.5, then move to VMware, then upgrade? Can you do the firmware at any time? What is the best order to do this? (we posted a question similar to this, but new info is the freaking Unity Version 5).
Solved! Go to Solution.
04-22-2015 10:05 AM
You are going to have to schedule multiple maintenance windows. If you are trying to minimize impact on production system, you might consider this strategy:
1 Maintenance Window 1 20 hours
Build out Vmware Hosts (can be done during business hours)
Build out CUCM, Unity and UCCX on VMware using Version 8.6
Build out CUCM on Current MCS hardware using Version 8.6
Backup Existing MCS CUCM Cluster and the Restore to New VMware Cluster
Note Service Impact - At this point CUCM servers are virtualized on 8.6 Unity and UCCX remain on MCS at current version. Each CUCM server will be off line during the upgrade to 8.6. and service impact to production system should be nominal and predictable. This is to be accomplished on an Off-Network LAN as NIC connectivity is required, the same IP’s are used, but can not reside on production network.
3.2 Maintenance Window 2 20 hours
Build out Unity as 8.6 on VMware
Use CISCO Cobras restore Unity to VMware.
Retire Unity 5.0 Windows MCS server.
Note Service Impact - At this point CUCM and Unity are now on VMware versioin 8.6. The production UCCX system will still be on MCS hardware. Service interruption should be nominal and predictable resulting in a modest interruption to Voice Mail during the time Server is retired an VMware Host for Unity is put on line.
3.3 Maintenance Window 3 20 hours
Build UCCX on 8.6 virtualized (exact version as upgrade)
Upgrade UCCX MCS Server one
Backup and Restore to virtualized environment 8.6 environment
Take Vmware snapshot
Upgrade UCCX MCS Server two to 8.6
Upgrade UCCX Server 1 to 10.5
Upgrade UCCX Server 2 to 10.5
Upgrade Desktop Clients (or migrate to Finesse and CUIC)
Note Service Impact – Production system is running on VMware as upgrade and move UCCX servers to VMware. Service interruption is nominal and predictable
3.4 Maintenance Window 4 20 hours
Upgrade CUCM Servers to 10.5
04-21-2015 08:05 PM
For Unity Connection you should first upgrade to version 8.x as explained here
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/8x/upgrade/guide/8xcucrugx/8xcucrug022.html
Then follow the upgrade guide for Unity connection 10.x
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/install_upgrade/guide/10xcuciumgx/10xcuciumg030.html
For CUCM, you can use Prime Collaboration Deployment 10.5
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/pcdadmin/10_5_1/CUCM_BK_U35347D2_00_pcd-administration-guide-1051/CUCM_BK_U35347D2_00_ucmap-administration-guide-1051_chapter_010.html
Phone firmware can be upgraded first before the cucm upgrade.
Upgrade the Unity connection to 8.x first as it is compatible with CUCM 5.x and later
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/compatibility/matrix/cucsccpmtx.html
Manish
04-22-2015 10:05 AM
