ā12-15-2023 11:33 AM
we have 3 cucm in our system.1 publisher and 2 subscribers
System version: 12.5.1.15900-66
we have two central phone (0) 7861
Active Load ID: |
sip78xx.11-5-1SR1-1 |
Inactive Load ID: |
sip78xx.14-0-1-0001-135 |
we restarted the all of cucm but there is no change.
not all time.but when the central number call iexternal or internal phone a few second call cutting.but not all call, random call,
ā12-15-2023 12:58 PM - edited ā12-15-2023 12:59 PM
Hello @ozden ozdugun
Do you have any log to provide ?
Enable detailed tracing on CUCM for the affected devices and review the call logs for the specific calls where the issue occurs. Look for any error messages or abnormal behavior.
ā12-16-2023 12:20 PM
I added 3 cucm log
ā12-15-2023 04:34 PM
Are those phones in the same LAN or they are in different locations?
Do those phones share the same Device Pool/CM group?
As M02@rt37 mentioned, please share CUCM SDL trace so we could give a look to them.
Carlo
ā12-16-2023 12:21 PM
yes two phone in the same desk; network ;switch;vlan and the same number
the log link
ā12-16-2023 11:58 PM
Can you please indicate a time when the issue happened so we can better dig on it ?
Carlo
ā12-17-2023 12:51 AM
3:36 pm
0 -1171 phone number
ā12-17-2023 02:34 AM
I analyzed that call and it seems a normal call closure by the generating phone. So the call is not dropped for an error but for a normal hang up from main phone.
We can also give a look to phone's logs if you can download it from its web page .
Please let us know.
Carlo
ā12-18-2023 02:46 AM
ı add the console log
download link https://we.tl/t-ZNDc6v6PcK
ā12-18-2023 03:38 AM
Hi @ozden ozdugun ,
Can you please tell me which phone you downloaded the log from?
Cheers
Carlo
ā12-18-2023 04:20 AM
central phone 0
ā12-18-2023 04:56 AM
Hi ,
I see that you have an inactive load of 14.0. can you please switch the phone's firmware version to that release?
Let me know
Carlo
ā12-18-2023 05:09 AM
how can ı do change thanks
ā12-18-2023 05:22 AM
You can go to "Device" --> "Device Defaults" and search for the phone's model. You will find a "Load Information" that is the active firmware, and "Inactive Load Informatio" which is the other available to be installed on the phone.
If you want to upgrade to the inactive load version for ALL phones of that model , you can click on the icon next to "inactive load" field and restart all phones of that kind.
If you want to upgrage one phone only, copy the inactive load field for that model and go to the specific phone though "Device" --> "Phone", search for the phone you need ad past what you copied in the "Phone Load Name" field and reset the phone.
Please let me know
Carlo
ā12-21-2023 12:56 AM
hi Carlo;
ı upgrade the phone but there is no change.
