when we call after a few min .call is cutting
ozden ozdugun
we have 3 cucm in our system.1 publisher and 2 subscribers
System version: 12.5.1.15900-66
we have two central phone (0) 7861
Active Load ID:
sip78xx.11-5-1SR1-1
Inactive Load ID:
sip78xx.14-0-1-0001-135
we restarted the all of cucm but there is no change.
not all time.but when the central number call iexternal or internal phone a few second call cutting.but not all call, random call,
15 Replies 15
M02@rt37
Hello @ozden ozdugun
Do you have any log to provide ?
Enable detailed tracing on CUCM for the affected devices and review the call logs for the specific calls where the issue occurs. Look for any error messages or abnormal behavior.
Best regards
https://we.tl/t-OyvWZR8jaK
I added 3 cucm log
Are those phones in the same LAN or they are in different locations?
Do those phones share the same Device Pool/CM group?
As M02@rt37  mentioned, please share CUCM SDL trace so we could give a look to them.
Carlo
Please rate all helpful posts "The more you help the more you learn"
yes two phone in the same desk; network ;switch;vlan and the same number
the log link
Can you please indicate a time when the issue happened so we can better dig on it ?
Carlo
3:36 pm
0 -1171 phone number
I analyzed that call and it seems a normal call closure by the generating phone. So the call is not dropped for an error but for a normal hang up from main phone.
We can also give a look to phone's logs if you can download it from its web page .
Please let us know.
Carlo
ı add the console log
download link https://we.tl/t-ZNDc6v6PcK
Hi @ozden ozdugun ,
Can you please tell me which phone you downloaded the log from?
Cheers
Carlo
central phone 0
Hi ,
I see that you have an inactive load of 14.0. can you please switch the phone's firmware version to that release?
Let me know
Carlo
how can ı do change thanks
You can go to "Device" --> "Device Defaults" and search for the phone's model. You will find a "Load Information" that is the active firmware, and "Inactive Load Informatio" which is the other available to be installed on the phone.
If you want to upgrade to the inactive load version for ALL phones of that model , you can click on the icon next to "inactive load" field and restart all phones of that kind.
If you want to upgrage one phone only, copy the inactive load field for that model and go to the specific phone though "Device" --> "Phone", search for the phone you need ad past what you copied in the "Phone Load Name" field and reset the phone.
Please let me know
Carlo
hi Carlo;
ı upgrade the phone but there is no change.
