03-27-2012
10:50 PM
- last edited on
03-25-2019
09:45 PM
by
ciscomoderator
Hi ,
Can anyone provide me code for adding phones through CME GUI.
Trying to create a web customer admin for L1 support, just want to give them access to add phones thats it.
Abhishek
03-27-2012 10:57 PM
Hi Abhishek,
CME has three level access
System administrator—Able to configure all system-level and phone-based features. This person is familiar with Cisco IOS software and VoIP network configuration.
Customer administrator—Able to perform routine phone additions and changes without having access to system-level features. This person does not have to be familiar with Cisco IOS software.
Phone user—Able to program a small set of features on his or her own phone and search the Cisco Unified CME directory. In Cisco Unified CME GUI 4.2.1 and later versions, phone users can use the GUI to set up personal speed dials for an Extension Mobility phone. The same credential for logging into an Extension Mobility phone can be used to log into the Cisco Unified CME GUI.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmegui.html#wp1072977
Ronak Patel
Please rate helpful posts.
03-27-2012 11:31 PM
Thanks for your prompt response , but when i configure customer admin it seems the access level is same as system admin one.
03-27-2012 11:42 PM
What XML file you are using. You will have to modify XML file ad upload it again in CME to get your requirement done.
Ronak Patel
03-27-2012 11:49 PM
created a simple xml file from notepad and saved it as .xml file. When i go and do web customize load webadmin.xml it gives me error
"cannot parse customization file webadmin.xml, aborted"
Code as follow :-
03-28-2012 12:14 AM
Try to use this
Hide
Hide
Hide
Hide
Hide
Hide
Hide
Hide
Hide
Hide
Show
Hide
Hide
Hide
Hide
Hide
Hide
Show
Hide
Hide
Hide
Hide
Hide
Hide
Hide
Hide
Hide
Hide
Hide
Hide
Hide
Hide
No
No
After upload it in flash do following
Router(config)# telephony-service
Router(config-telephony)# web customize load filename
and
telephony-service
web admin customer name username password string
Ronak Patel
03-28-2012 05:59 AM
You may be able to do that then find the the GUI does not allow to associate an ephone-tempalte that is a very important feature.
Unfortuantely the GUI does a bad job at most tasks, the only solution fro delivering professional systems is to avoid it.
