07-26-2019 11:43 AM
All,
I was wondering if anyone has any insight in the process for rebooting expressway environment (C & E)
What is the proper proceedure?
What would be your pre- post checks?
Solved! Go to Solution.
07-29-2019 07:06 AM
07-26-2019 12:48 PM
07-26-2019 01:41 PM
@Adam Pawlowski Thank You for your detailed write up. This will be extremely helpful in my maintenance.
We are actually powering the VM's off to move them to a new VM version.
Can shutdown be done via GUI?
Would you start with C or E?
Is there anything other than what you highlighted in your notes that i should check (ie..services, etc..) when the servers are back up?
07-29-2019 04:57 AM
07-29-2019 06:21 AM
Thanks again for your detailed information!
We have C&E (2 pairs), so i will do the master pair first and then the secondary pair second.
After each come back up - I will check to make sure the traversal zones are up and then the Firewall is up. Question - I was looking through the configuration and wasn't able to notice a section to tell me if or if not the firewall is up / down. Do you have a suggestion for where i would check to verify?
Then I will test calls via MRA and B2B as suggested.
Thank You,
07-29-2019 07:06 AM
07-29-2019 10:18 AM
@Adam Pawlowski Thats perfect - thank you for all your help!!
