Configuring an Informix System DSN to link to Unity Connection
James Hawkins
Level 8
Level 8
I want to use the wallet card wizard from ciscounitytools and to do so I need to use the Informix ODBC drivers to link to Unity Connection.
However I cannot find the the information required to set up a System DSN under Windows XP. Specifically I cannot find what the Database Name should be set to.
When I have done similar connections to UCCX for wallboard data etc. the database name was db_cra.
Can anyone tell me what it should be for Unity Connection?
Rob Huffman
Hi James,
Hope all is well my friend!
Please excuse my COMPLETE ignorance here, but when we used the Wallet Card Wizard
we didn't need any DSN info etc. Just installed the available ODBC drivers (link on page) on xp
and followed the other steps that were perfectly described here
http://www.ciscounitytools.com/Applications/CxN/WalletCardWizard/WalletCardWizard.html
Cheers!
Rob
Hi Rob,
Thanks for the reponse. I am not too hot on databases either but my understanding is that a System DSN has to be created under Windows for each database link.
Below is an image from my PC for the System DSN that I configured when I was setting up a System DSN to link to a UCCX server.
The setup requires a database name to be entered. This is easy for UCCX - it is db_cra - but I cannot find which database name I need to use for Unity Connection.
I am happy to be proved incorrect about the requirement for a System DSN if anyone can advise me otherwise.
Cheers
James
Rob Huffman
Hey james,
Maybe this info form Lindborg himself may help
https://supportforums.cisco.com/message/1212478#1212478
Cheers!
Rob
