DTMF issue on SIP trunk
shaikh ibrahim
                   Hi there ,
                                I am facing issue on outbound calls where ever i make call to any Main number but it is not accepting extension numbers. i think is a DTMF
issue but which command i will use under dial-peer voice dial -peer.
CUCM --- VG --SIP---Service provider
dial-peer voice 20 voip
  translation-profile outgoing OUT-SIP
destination-pattern .T
voice-class codec 1
session protocol sipv2
session target ipv4:10.200.7.157:5060
session transport udp
dtmf-relay rtp-nte
no vad
Any help will be highly appreciated
Shib
Tony Cilli Jr
Don't be afraid to actually setup several different DTMF-relays under one statement, to get the DTMF Tones working on the SIP trunk to my provider, here's an example of my outbound dial-peer.
dial-peer voice 100 voip
description Outbound Voice SIP Calls
session target sip-server
voice-class codec 1
voice-class sip early-offer forced
voice-class sip profiles 100
dtmf-relay rtp-nte cisco-rtp sip-kpml sip-notify
no vad
HTH,  Tony
Please rate this if it helps.
I tried but same ay help will be higly appreciated.
Verify with the SIP ITSP what type of DTMF they support:
  • Notify <---> Notify since 12.4(4)T
  • RFC2833 <---> Notify since 12.4(4)T
  • Notify <---> RFC2833 since 12.4(4)T
  • Inband G711 <---> since 12.4(11)T [Requires Transcoder]
Take a look on this doc:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_example09186a00808f9666.shtml
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
I have similar problem
We have SIP trunk with CME 8.6 and 10 SCCP (7960,7975) phones, also UM with Exchange 2010 , everything work perfectly until we added two SIP client phones.
SIP client phones 9971 and 7906 have issue with sending DTMF signals.
From both SIP phones I can call and receive calls but when I call some number with auto attended or voice mail on internal or external number I have problem to choose options ,
I hear DTMF tones but destination party does not.
I can leave message, which means that I have two way communication.
I notice this trying to access ours voice mailbox on Exchange 2010 I can make call but no DTMF command are recognized I cannot enter PIN for mailbox I hear DTMF tones but UM does not
everything is normal with SCCP clients phones , problem localized on SIP clients phones.
My configurations for SIP and those two phones are
voice service voip
gcid
no cti shutdown
callmonitor
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
call start slow
modem passthrough nse codec g711alaw
sip
header-passing
registrar server expires max 1200 min 60
early-offer forced
midcall-signaling passthru
voice register dn 1
number 101
call-forward b2bua noan 555 timeout 20
allow watch
name BOSS1
no-reg
label 101 BOSS1
voice register dn 10
number 110
allow watch
name SHOP
no-reg
label 110 SHOP
voice register pool 1
id mac 04C5.A4B0.3B0D
type 9971
number 1 dn 1
dtmf-relay sip-notify
username xxxx password zzzz
codec g711alaw
camera
video
voice register pool 10
id mac 001E.7A25.EEA4
type 7906
number 1 dn 10
username xxxx password zzzzz
codec g711alaw
Configuration of voicemail dial-peer
dial-peer voice 555 voip
description ** Exchange Unified Messaging **
destination-pattern 555
session target ipv4:192.168.2.203:5065
session transport tcp
dtmf-relay rtp-nte
codec g711alaw
fax rate disable
fax protocol pass-through g711alaw
no vad
Any idea what is wrong or do you how can I troubleshot the problem
