making calls to SOAP API using Mulesoft
ravi.kumar1
I use Mulesoft's anypoint platform for automation and making calls to API, i have made calls to RESTful APIs successfully many a times. Recently i tried to make calls to CuCM SOAP APIs, but am failing to establish the connection. Does any one have experience using Mulesoft. Below is the link describing about my issue
https://help.mulesoft.com/s/feed/0D52T00005ML9TCSA1
Recommend you to head over to DevNet for this line of questions.
Response Signature
Jonas Fraga
Hello, Ravi.
I've some experience on SOAP UI software which is great for SOAP Requests because we can use the WSDL Schema from CUCM to work on it: https://www.soapui.org
Can you relate more what kind of issue you're facing on Mulesoft?
