Request for ideas for Unity Connection documentation
Scott Hills
Hello, I'm a Unity Lead in the Technical Assistance Center and I am looking for ideas on documentation you might think missing or lacking on Cisco.com. Who better to ask than our customer base that utilize our documentation most often.
In this case I am requesting ideas for Unity Connection, PIMG, Unity, Speechview, and perhaps Tools found on CiscoUnityTools.com
The ideas could be in areas such as Troubleshooting or How to do a certain feature, also design is a possible area, and other ideas you may have.
Please reply back on this discussion with your ideas. I will most likely not respond unless I need more clarification on your idea. I'm not going to give that's a good idea or not a good idea. In this case I'm using this more to brainstorm what the customer base feels would be helpful and is not already present.
I appreciate your particiation in this endevor and look forward to your feedback.
Scott
layhlaing
Hi Scott,
I would like to thank you for this brilliant idea to improving documentation on cisco.com, especially for Unity Connection. I am sure there will be a lot of guys out there who will thank you for this.
I think the documents in the style of
https://supportforums.cisco.com/docs/DOC-24164 and
https://supportforums.cisco.com/docs/DOC-24164 are really helpful. However, I can't find such documention in the context of call handlers in Cisco Unity Connection. In my opinion, they are addition to what Cisco has as configuration examples.
Thank you & regards,
Lay
