07-17-2020 01:18 AM - edited 07-17-2020 01:26 AM
Hi guys,
we have set up a bunch of RDPs and some of our staff would like to define a custom ring schedule. Unfortunatly there is no option to do it within the user interface, so I have to do it via CUCM - very annoying.
So question 1: Is there any possibility to edit the ring schedule within the user interface and
question 2: I have to specify a time zone but there is no option to specify daylight savings (hope EU gets rid of it anyway) so I have to change every profile twice a year!? Why can't I use system time - would be much more convenient...
Thanks for your help, have a nice weekend
Stephan
Solved! Go to Solution.
07-17-2020 02:05 AM - edited 07-17-2020 02:16 AM
This should be possible to manage by the users them self on the user CM page. See below pictures taken for this on my TCT device.
This should from what I remember work the same with RDPs.
The timezone you set would use the DST settings that the system has for the zones that gets installed with the TZ update file for CM.
07-17-2020 09:44 AM
I added a RDP to my account to check if it’s the same and it was. So you should be able to have your users maintain this themselves.
07-19-2020 11:50 PM - edited 07-20-2020 12:04 AM
Thanks for your help, that did it!
But no wonder I missed this option. Yours is named clearly, mine looks like:
Any idea how to edit this cryptic label?
Thanks again
Stephan
08-20-2020 01:50 AM - edited 08-20-2020 01:52 AM
Bringing light into the dark...
If you have configured the ring schedule from within CUCM, it generates a cryptic random name. You can rename this ring schedule when logged in as user.
Didn't find a way to rename the ring schedule within CUCM yet - anyone?
Cheers
Stephan
