Unity Connection 12.0.1 - Unexpected Inconsistency File System Error
Quintin.Mayo
Level 3
Level 3
One of our voicemail server crashed and when rebooting it produced the attached error.  I'm assuming the recovery disk will be need to correct the issue? If the recovery disk doesn't work then rebuild the system?  Can anyone provide any guidance in this matter, it would be greatly appreciated.
Jaime Valencia
That's pretty much it, even if the recovery disk works I'd still suggest to perform a re-install whenever possible
java
if this helps, please rate
