about Licensing cisco unified system
imami
I have same notification from cisco ucs about licensing as shown in the screen shot below:
What is it grace period?
Can I still use the 40Gbps ports  in grace period forever without any probelm ?
Thank you.
Kirk J
Grace period means you are using a port that you have not purchased licensing for.
Kirk...
Thank you for your replay.
How long can I use grace period ?
What happens if the period has finished?
Any update please ?
Hi.. you can continue using the ports..no operational impact will be observed...
