about upgrade n1000v problem
YI-MING TSAI
There are two VSMs and four VEMs on ESXi 5.1 servers.They are all the same version,Release 4.2(1)SV2(1.1a).
I want to add two two ESXi 5.5 servers.
Can I just install Release 4.2(1)SV2(2.1a) on two ESXi 5.5 server,then add two VEMs with release 4.2(1)SV2(2.1a)
to VSM with release 4.2(1)SV2(1.1a)?
or I have to upgrade my VSMs to Release 4.2(1)SV2(2.1a)?
sprasath
VSM needs to be upgraded as well.
A 4.2(1)SV2(1.1a) VSM would be able to talk to a 4.2(1)SV2(1.1a) VEM, but not the other way around. You'll see a message in the log saying that the VEM is not backward compatible.
Shankar
sprasath
Shankar
Thank you,
Yi-ming
If I upgrade VSM to release 4.2(1)SV2(2.1a) and keep four VEMs with release 4.2(1)SV2(1.1a).
Can they work fine?
