Andromeda Management Port
dan.laden
When looking at the UCS CIMC configuration, several ports are listed as open.  Most are explainable but i cannot find info on the follow two ports.  What are they and what are they used for?
8889
Andromeda Cloud Port
8888
https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/sw/cli/config/guide/4_2/b_cisco_ucs_c-series_cli_configuration_guide_42/b_Cisco_UCS_C-Series_CLI_Configuration_Guide_41_chapter_01.html
Steven Tardy
https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/sw/gui/config/guide/4_0/b_Cisco_UCS_C-series_GUI_Configuration_Guide_40/b_Cisco_UCS_C-series_GUI_Configuration_Guide_40_chapter_010001.html#task_D1C22EDEC0BA41A59475EDA920AB6B13
Port numbers 8888-8889 are reserved for Intersight communication.
I knew of port 8889 on localhost for some Intersight "device connector" debugging, but 1) wasn't aware of 8888 and 2) don't know that access is needed outside of CIMC (not localhost only).
