B200 M5 won't allow factory reset from Maintenance
srj214
Hello everyone, I'm new to UCS and have a bunch of B200 M5 servers I need to test.
I was able to factory reset the first blade I tested but the 6 blades following do not allow it.
I right click the blade and go to Maintenance where I see all the options.  Even though
factory reset is listed in the options, it will not let me click it.  Can you please let me know
what my issue might be?
Thank you
Also, I need to have my drives set to JBOD and some are set as unconfigured good.
If I do a factory reset of the blade and also click the option to reset the raid controller, will
it set those back to JBOD or do I need to KVM into the switch as I've read.  I get an error when
trying to set to JBOD saying my controller does not have JBOD enabled.
Thanks again
0 Replies 0
