B460 not detected
Tejas Kunte
i have a pair of B460 M4 servers that my chassis is not able to detect.
i have installed the latest firmware and infrastructure packages.
the coupler also is installed correctly
any idea what could be the problem ?
5 Replies 5
Tejas Kunte
want to add to the above.
1 power supply on the chassis is dead. would that make a difference ?
Can you please post the error message (discovery failed ??)
2.2.3d ?
Chassis with which model of IOM ? 2204/2008 ?
that's the problem
there is no error message, ucsm shows the slot as undiscovered.
1 power supply of the chassis has failed. is there a requirement for the B460s for all power to be available.
Do you mean 3 out of 4 PS are working ok ?
Just take one B460-M4 out of the Chassis and see what happens !
this is all set.
i had to suspend the FIC from UCS Central and reseat the blades.
all B460s are now visible
