bind vmfex interfaces to exact fabric
raven428c
Is it correct way to bind interface of virtual machine to exact fabric?
First, I created dynamic connection policy:
Then I used this policy to create virtual machine adapter template:
And finaly I created this adapter in virtual switch:
Is this enough or should I do something else? Should I change something here? I can't figure out how dynamic will distribute beetween fabrics. I would like have possibility to bind vmfex interfaces to exact fabric at virtual machine configuration. Is it possible with ucs vmfex?
Evan Mickel
The Protected Pref A or B option is how this is completed, if any Dynamic vNICs created using that connection policy will prefer the A fabric and will attempt to pin as such during creation.  However because ALL dynamic vNICs are protected and failover enabled, they will attempt a failover in events that would dictate one.
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/vm_fex/vmware/gui/config_guide/b_GUI_VMware_VM-FEX_UCSM_Configuration_Guide/b_GUI_VMware_VM-FEX_UCSM_Configuration_Guide_chapter_010.html
