C-Series FCoE with VIC 1225 and Nexus 5548 Not Working
Anthony
We're having issues with C-Series seeing a LUN on a Netpp array.  In a nut shell, the fcns registration is not moving through to completion.  We should be seeing "scsi-fcp:init fc-gs" unde the FC4-TYPE: FEATURE column, but as you can see it's not there.
FCID        TYPE  PWWN                    (VENDOR)        FC4-TYPE:FEATURE
0x020000    N     20:00:00:00:00:99:02:02
Using debug I see the 5k discovery packet go out, but VIC is not responding.
Here is the 5k config;
vlan 11
  fcoe vsan 11
vlan 100
vsan database
  vsan 11
fcdomain fcid database
  vsan 11 wwn 20:00:00:00:00:99:02:02 fcid 0x020000 dynamic
interface vfc9
  bind interface Ethernet1/9
  switchport trunk allowed vsan 11
  no shutdown
vsan database
  vsan 11 interface vfc9
  switchport mode trunk
  switchport trunk native vlan 100
  switchport trunk allowed vlan 11
  spanning-tree port type edge trunk
On the C-Series under vHBA, we have the native vlan 100 vs. using "Default".  I have seen conflicting posts, but we tried using default and 100 with no luck.  We have the latest OS drivers installed per the latest 1.5 C22 ISO.  Any ideas on what's going on?
Thanks!
Anthony
So I figured out....despite turning on FCoE, it doesn't turn on the corret QoS queues needed by default.  You need to add the following lines of code;
system qos
service-policy type qos input fcoe-default-in-policy
service-policy type queuing input fcoe-default-in-policy
service-policy type queuing output fcoe-default-out-policy
service-policy type network-qos fcoe-default-nq-policy
As soon as I did everything come up fine.
