C200 firmware Host Based Upgrade loop
Rebooted a UCSM managed C200 this morning, and it keeps entering the Host Based Upgrade utility on reset. After POST, a screen appears with "Fetching System Information.....", and then the following appears:
Selecting "q" repeats the cycle, and selecting "y" brings up the following screen:
I just want to boot the OS, leaving the firmware unchanged.
This appears to be the only server doing this, and I'm not sure how to get out of this loop.
Cheers,
Paul
P.S. Server firmware currently shows as follows in UCSM:
atl01-ucsf01a-A# show server firmware 18
Server 18:
    CIMC:
        Running-Vers: 1.4(3k)
        Package-Vers: 2.0(3c)C
        Update-Status: Ready
        Activate-Status: Ready
    Adapter 1:
        Running-Vers: 2.0(3c)
    BIOS:
        Running-Vers: C200.1.4.3f.0.032920122244
        Update-Status:
    RAID Controller 1:
        Running-Vers:
        Package-Vers:
        Activate-Status:
    RAID Controller 2:
        Running-Vers: 01.32.04.00
        Package-Vers:
Keny Perez
Level 8
Level 8
Paul,
Evidently, the server is NOT booting up from the local disk or SAN as it is using the Host Upgrade Utility to boot up, so definitely you should have a .ISO file mounted in the Vïrtual Media"tab or a CD in the DVD unit.
Please check VM tab and DVD unit, reboot the server, get into the BIOS and make sure that you are using the correct boot order to boot up the box, either the RAID option to boot up locally or to boot up from SAN if that is what you are trying to do.
Please keep us posted on what happens after you check on the above.
-Kenny
Daniel Laden
Level 4
Level 4
I would be curious to know if the virtual media tab has any mounted or if there is a CD in the CD tray?
Thank You,
Dan Laden
PDI Helpdesk
http://www.cisco.com/go/pdihelpdesk
Keny Perez
Level 8
Level 8
Paul,
-Kenny
There was indeed a CD in the DVD unit, which our datacenter folks have removed. The server now boots as expected. :-)
Thanks for your help.
Paul,
Any time,
-Kenny
