C220 M3 problem ( Boot Cycle at "config...Screen)
jalen
Hi Pro
UCS C220 M3 now Bootig at "Config..." Screen  and cycle  ;but the CIMC is OK can access from web
Manuel Velasco
Hi Jalen,
If your server keeps looping at the configuration screen most likely the bios is corrupted and you need to recover it.
See the documentation to help you recover the corrupted BIOS. I would suggest that you try procedure 2.
Using the BIOS Recovery Header J41
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/hw/C220/install/C220/install.html#pgfId-1416982
To get the recovery.cap file you need to download the HUU of the current version installed on your server (you can find this version from the cimc) and extract the iso.   For example for the HUU version 1.5(7e) the recover file is located in the following location
ucs-c220-huu-1.5.7e\C220M3-1.5.7e\1.5.7e\bios\recovery
c220 m3 huu download site
https://software.cisco.com/download/release.html?mdfid=284296253&softwareid=283850974&release=2.0%283i%29&relind=AVAILABLE&rellifecycle=&reltype=latest
Let me know if this helps
Walter Dey
Sorry, can you please clarify ! what is your problem / question ?
Manuel Velasco
Hi Jalen,
