C220M4 Firmware
gaigl
Level 3
Level 3
we've got 2 SNS 3515 (C220M4) and on one of them I made a mistake with firmware management, so with a browser I don't get the login form. (with Internet Explorer, Firefox wants the Flashplayer Plugin, no way on this Management Server)
the Machine with working firmware:
BIOS:
    BIOS Version: C220M4.3.0.3a.0.0321172055
    Backup BIOS Version: C220M4.3.0.4b.0.0
    Boot Order: CDROM,HDD
    FW Update/Recovery Status: None, OK
    UEFI Secure Boot: enabled
    Configured Boot Mode: Uefi
    Actual Boot Mode: Uefi
    Last Configured Boot Order Source: CIMC
    One time boot device: (none)
Cisco IMC:
    Firmware Version: 3.0(3S2)
    Current Time: Thu Apr 30 12:15:57 2020
    Boot-loader Version: 3.0(3S2).36
    Local Time: Thu Apr 30 12:15:57 2020 UTC +0000
    Timezone: UTC
    Reset Reason: ac-cycle
the Machine nor working (GUI Login):
BIOS:
    Backup BIOS Version: C220M4.4.0.2d.0.0627191019
    Boot Override Priority:
Cisco IMC:
    Firmware Version: 2.0(9c)
    Current Time: Thu Apr 30 12:17:36 2020
    Boot-loader Version: 2.0(9c).36
    Local Time: Thu Apr 30 12:17:36 2020 UTC +0000
    Timezone: UTC
    Reset Reason: graceful-reboot
Is there a way to install a firmware without the GUI?
I know I can activate an alternative BIOS but I guess the problem is the cimc-firmware
any help?
Kirk J
If you have ssh access, then you can attempt upgrade and activation of CIMC firmware.
See https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/sw/cli/config/guide/b_Cisco_CIMC_CLI_Configuration_Guide/Cisco_CIMC_CLI_Configuration_Guide_chapter11.html#concept_2C13E744DD59456685EE8A69B026FD72
Procedure
  Command or Action Purpose
Step 1 Server# scope cimc
Enters the CIMC command mode.
Step 2 Server /cimc # scope firmware
Enters the CIMC firmware command mode.
Step 3 Server /cimc/firmware # update tftp-ip-address path-and-filename
Starts the firmware update. The server will obtain the update firmware at the specified path and file name from the TFTP server at the specified IP address.
Step 4 (Optional) Server /cimc/firmware # show detail
Displays the progress of the firmware update.
This example updates the firmware:
Server# scope cimc
Server /cimc/firmware # update 10.20.34.56 /user/updates/filename
robertdemay
I believe Firmware Version: 2.0(9c) requires java 6 64bit
Kirk J
Procedure
Server# scope cimc
Thanks great!
that's what I was looking for
