Can CIMC Inband Management VLAN same as Hx-Mgmt VLAN?
Markus5849
Just wondering can I use the same VLAN during Hyperflex standard wizard creation for Hx-mgmt-vlan and CIMC Inband Management?
Or it must be different?
Steven Tardy
I haven't ever done that combination, but it should be okay for HX-mgmt and inband-CIMC to be the same VLAN.
If it works (or doesn't work) for you, then reply back.
