07-25-2013 08:37 AM - edited 03-01-2019 11:09 AM
Please I need your help to know if I can create vhbas of 8GB speed with mezzanine card M81KR.
07-25-2013 08:52 AM
Jaqui,
I don't belive there is an onption to will allow you to set the speed on the vhbas on any adapter. But you might be able to select the speed on your FI uplink interfaces.
07-25-2013 08:53 AM
No the FC ASIC in the M81KR is only 4GB FC.
The second gen VIC (1240/1280) are 8GB FC.
Robert
07-25-2013 09:01 AM
Hi Robert and Manuel,
Thank you for your help.
Robert please if you know where can I find this information about the vhba speed?
I tried to find this but only I found the datasheet of this card, on the datasheet does not say anything about it.
Thanks you.
07-25-2013 10:13 AM
By default, vHBA on M81KR is limited by physical interface i.e 10 Gbps.
What is the version of UCSM and capability catalog ? It should be saying as 10 Gbps.
You can rate-limit it ( recommended only if you are aware of your design and traffic load ) to limit to 4 or 8 Gbps.
Check the Rate limit field under QoS policy.
Padma
07-25-2013 11:16 AM
Hi Padranas,
Thank you for your response.
I am confusing about it......
To understand what you said. For example:
My UCS environment is: Chassis 5108 + 3 Blades B200M2 + M81KR Mezzanine card + 2104xp FEX + 6124xp FI .
We have 2 SAN switch brocade of 4GB speed by FC port connecting to the UCS FI and the Blade server has the service profile configure to use vhba of 4GB speed, I cannot change this configurations. We want to replace the Brocade SAN swtich by 2 new MDS 9148 of 8GB speed by FC port.
Can I be able to reconfigure the vhbas on my environment UCS to work with FC8GB replacing the Brocade switch to MDS?.
Our goal is improve the SAN speed from FC 4GB to FC 8GB.
We have a EMC stroage that support FC 8GB, but it is running to 4GB, because of Brocade SAN switch.
Thanks for your time.
07-25-2013 11:55 AM
Within UCS, it is all 10G. If there is no competing traffic and with default QoS policy, FCoE traffic via vHBA can make use of the whole pipe.
When you replace your SAN switch with MDS, all you need to mak sure is the FC uplinks are operating at 8 Gbps.
No need to worry about vHBA FC speed.
In addition, you can take advantage of port-channel feature and bundle FC links together between FI and MDS.
Padma
