Looking at some IOM log output for grid based configurations, I see the following:
Grid : 0
Active PS : 0
Spare PS : 1
Unavailable PS :
Grid : 1
Active PS : 2
Spare PS : 3
Unavailable PS :
For actual numbering this means PSU #1 and #2 are expected to be on the same grid source, and #3 and #4 are expected to be on the same source.
If you have it wired otherwise,, then the UCSM may put wrong PSUs to sleep (Spare), in which event a single Grid impacting event can knock down both active PSUs.
definitions for example below:
PSUs: 1,2,3,4
grids: a,b
+ : PSU fully on
- : PSU source failed
s: PSU in spare/standby mode
Your config:
1 2 3 4
a b a b
+ s + s
then you loose grid 'a' power source
1 2 3 4
a b a b
- s - s <<<2 PSUs lost AC, and 2 PSUs in standby
If you have it wired for grid on 1,2 and 3,4 what should have happened is:
1 2 3 4
a a b b
+ s + s
- - + s <<<2 PSUs lost (grid a), and only 1 PSU originally in standby on b grid
at which point you have at least one PSU fully online, and then it brings the 2nd PSU member of the grid online
1 2 3 4
a a b b
Hope this helps,
Kirk...
