10-02-2015 06:20 PM - edited 03-01-2019 12:23 PM
i have a Cisco UCS C210 Server in the lab. I had to power cycle the server for some reason. After power cycling, the CIMC ping works for some time (for about 10 seconds) and after that it becomes unreachable.
I tried hooking up the VGA terminal to the back panel. I was able to see the CIMC IP address and such set correctly. Then i exit the CIMC settings page and let it boot up..At that point it loses IP connectivity.
Any hints on what could be going wrong here ?
10-03-2015 12:05 AM
Is the CIMC in the same IP subnet ? is there a router in the path ? fw ?
Was it ever working or not ?
Check arp cache, mac address on the switches
10-03-2015 08:50 AM
thanks Walter for the response. This UCS had been working for the past one year.
There is a switch in the path (that connects to the engineering lab network).
I don't have access permissions to the switch to check that out.
10-03-2015 10:05 AM
If this has been working before, and you didn't make any changes ...could it be duplicated IP address ? Turn off the server, and ping the CIMC IP address.
10-09-2015 10:39 AM
Hi walter,
Thanks for your time. Our lab admin was able to resolve the IP address issue. Not sure what the problem was though. It seems to work now.
