Cisco FI(v2.5) + FEX(2232PP) = unsupported-model
cyber_indian
We are running a lab for a future project using "cluster setup" - Cisco Fabric Interconnect with FEX. The lab setup is 6120XP version 2.5(2a) and 2232PP FEX, yet it keeps trowing off erros. One error that sticks out is F1635("Fex N2K-C2232PP-10GE is not supported in this version of UCS Manager"). According to documentation UCSM v2.0.2 and up should support FEX on both 6100 and 6200 FICs. What am I doing wrong ? I appreciate any help.
Wes Austin
UCSM 2.5.X is for UCS Modular (M-Series) Cartridges.
UCSM 2.X.X (For example 2.2.5B) is for UCS blade/rack servers.
If you upgrade your UCSM software to be a correct version, you should no longer see the error.
HTH,
Wes
Wes Austin
HTH,
Wes
Thank you very much, that was exactly the issue. I hate it when I was so much time on something so trivial. And I wish it had been labeled better, so other don't make the same mistake.
