Cisco HX system Login vSphere Web Client show internal error
stanleychou
I have been newly install HX system version 1.7.3 finish
and Login to vSphere Web Client show internal error -
Unable to load resource module from /vshpere-client/pluginui/locales/StorvisorUi-zh_TW.swf
Vcenter version is 6.0U2
Is it mean not support tranditional chinese?
2 Accepted Solutions
Clifford Aldan
stanleychou
Did you successfully re-deploy your 1.7.3 HX cluster?
There's some cleanup that needed to be done in vCenter to clear the old information prior to re-deploying - such as removing the plugin from the vCenter MOB and deleting the HX cluster of the old cluster
Hi, stanleychou
HyperFlex is slated for language localization at later release (post 2.0) , which explains why you are getting this message
Clifford Aldan
stanleychou
Hi Clifford
The vCenter is All new deploy, and try to re-deploy new vCenter and new 1.7.3 HX system 2 times.
and it continue appear error mesage.
Hi, stanleychou
